90 da tranny help
90DATeggy
The Pussi Snatcher
im doing a clutch job on my car since its been pass due...and clutch is starting to show slip badly
so im looking to try and drop the trann it wont come out all bolts are out and the shift linkage is down on the floor and it still wont give out...i pryed a flat head in between the bellhousing and the engine and tapped it in there and i see the gap and nothing...
i also tryed to use the 2 floor jacks and changed the different angles and heights and nothing comes out...im really stomped it blows....and i hammered it odwn and different spot's to try and open the gap more but nothing
there are dowel pins that align the tranny when its going on..if you didnt clear those it wont come out,,also make sure the input shaft is all the way clear of the motor...
and the rear mount vracket is undone,and the axles are out,
all ready done thanks for the tips i was the rear bracket and the side mount i had to yank it out
