90 HB DX cluster swapped with 90 LX cluster?
Discussion in 'ECU's, Electronics, and Tuning' started by lonelydriver, Aug 24, 2004.
  1. lonelydriver
    lonelydriver Member
    i want to swap a 1990 LX sedan cluster which has a tachometer, into my 1990 HB DX which does not have a tachometer. is it a direct swap? i won't have to do any re-wiring for the tach to work, will i?
    thanks all.
  2. tigger97005
    tigger97005 Junior Member
    No rewiring will be needed as long as the 90-91 gauge package is being used for a 90-91. The 88-89 gauges are different.
  3. projectDx
    projectDx Junior Member
    i went ahead and swapped the clusters. everything was a perfect match, plug and play, no left over wires. however... haha, i still need to fix/swap my motor to find out if it's working.
