90 hb wont start
Discussion in 'Civic and CRX - EF' started by 1bar crx, Feb 2, 2009.
  1. 1bar crx
    1bar crx old guy
    wilmington,nc
    My sister has a 90 dx , she said it died in the drive way and will not start. I have checked to make sure it had gas, The fuel pump( it's coming on), The distributor(got a new one also) but the car will not fire. It has a 16 code,witch is for the injector but i can hear it working and have tryed to spray starting fluid in it and nothing will happen. Thanks for any help, I know she will be very greatful(i know I will be to get her out of my car.lol)
  2. superorange
    superorange New Member
    check your ground
  3. 1bar crx
    1bar crx old guy
    wilmington,nc
    checked them already. one of the first things i did.. everything seams to be woriking but there is just no fire???????????
  4. DESPAIN
    flower mound TX
    Maybe the dizzy?
  5. Fernpatch
    Fernpatch Member
    Bellingham,WA
    Try unplugging on injector and than start it. Repeat process with the other injector. I have seen these cars short out one the the injectors which screws with the ecu and cause it to not run.
  6. sevenhillsbilly
    sevenhillsbilly New Member
    if that doesnt work try the master relay
  7. yodaesu
    yodaesu New Member
    Take a long screwdriver and a hammer and try tapping on the starter while somebody tries to turn the ignition. If it does not turn over after that then get a cheap wal-mart or radio-shack voltmeter and touch it to the positive and a ground on the car, it should read around 12.** when car is off and around 14.** when the car is on. If it's anywhere below that then you should invest in maybe a new alternator or a battery.
