'90 honda hb dx engine light
nikos33
i have a 1990 honda civic dx with stock motor, the check engine light comes on all the time, the car wont start untill the light goes off?
Lift up the passenger side floor mat/carpet up near the firewall and then watch the little blinking light through the small window on the kick plate that's bolted to the floor. Count the flashes until they start to repeat...there will be a pause between different code flashes. Compare your flashes to a code list and go from there. Good luck!
