90' Ls To 90civic Dx
oundee
i got the whole car ls integra and would the wires just fit in the civic dx instead of using the si wires to run the injection any one had did problem before???
i think i understand what you are trying to say but it is not that clear. Yes if you are putting an b18 motor in a 90dx, then you can use the DX harness and add injection wires and distributor plugs from the LS harness. As long as it is a b18a and it is obd0 then you can use the integra injector resitor box too.
