90 LS trans syncro problem!!!
Discussion in 'HYBRID -> ED-EF / DA' started by ricancivic_91, Mar 24, 2009.
  1. ricancivic_91
    ricancivic_91 New Member
    Sup guys finally got my hatch running perfect after all the work i had to do with the wiring. But now my fifth gear pops out when im on the freeway but my question is should i replace that syncro or should i just find another tranny? And if i replace that syncro down the line would any of the other syncros go bad?
  2. BrokenRex
    BrokenRex New Member
    it's not the synchro, it's wear on the shift fork because you (or whoever owned that trans) would drive in gear while resting his hand on the shifter.
  3. ricancivic_91
    Well the tranny belonged to my cousin b4 me and he had it in his hatch and he said it was perfect when he had it.
  4. BrokenRex
    right, because he drove while resting his hand on the shifter, preventing the shifter from popping out.
  5. jizoedotcom
    jizoedotcom New Member
    austin,tx
    if u got a 90 LS tranny u prolly got a cable tranny. i would definitely replace it. LS cable trannys are affordable.
  6. whiterabbit06
    Crestview, Fl
    If you want to look at the write-up in my post to take a look at the insides of the tranny.
  7. 97hatch
    97hatch ?
    Anderson IN
    yes you will most likely need more than the syncro for 5th gear as a poping out of gear problem is a little more serious
