pdqcrx
Member
Put these axles in the crx and when I tightened down on them the wheels locked up. Took it apart and seen the dust shields crushed the rubber seals on the axels. The teg ones are bigger. Do I need to put the teg bearings in the crx or do I need to change something else. I removed the metal race for the dust shield and now they work fine but will it cause problems with bearings later. The axels are still sealed .
