90 si hatch/ lsvtec swap
ek9r
im posting this for my friend. its a 90 si hatch, lsvtec, b16 head, and cable tranny.
question: what ecu does he need ?( wants to keep it obd0 for some reason) what axles, dizzy, and shift linkage. engine is built and just witing for the parts i listed. thanks for all your help in advance.
I don't know about axels, if I had to guess I would say the same that you use for a B16 swap :) As for ECU and distributor he needs those from an Integra XSi (or any other car from Japan that came with a B16 before 92).
ok so he needs a jdm pr3 ecu? and he cant use dizzy from usdm obd0 tegs?
the only linkage that will work is what? :blink:
No, the LS distributor will not bolt to a VTEC head.
ahhh, now i understand! when i look at the non obd dizzy, what should it say on it so i know its the jdm one that i need?
thanks for your help
either a pr3 or a pw0 ecu will work with the swap. as for a dizzy, call steve down at hmotorsonline for a obd0 b16 diz itll run you about 150 plus shipping and i know hes got at least 2 in stock cuz i gotta pick one up monday morning.
818-723-2572
