90 si meagan catback help
Discussion in 'Civic and CRX - EF' started by HATCHET_HONDA, Jan 16, 2008.
  1. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    so i bought a megan cat back sytem for my hatch. stock direct fit converter....upon install i notice the mid pipe is 12 3/8 inches too long! bolt on my ass! the rear section went together smoothly. its too long in the middle and the hanger doesnt match the body and is off by 10 inches. anybody ever have problems like this with megan products?
  2. JermBizzle
    JermBizzle Active Member VIP
    I doubt that you're the only one with that problem, my apexi worldsport was the same way, it was way too short to just bolt on, so I had to take it to a muffler shop to have a flexpipe and more piping welded in...
    I guess the exhaust companies can't predict the length of every single car's exhaust and previous work done to the system that may affect the length of it.
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    you sure you don't have the midsection on backwards?
  4. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    They clearly sent you the wrong catback, thats all. Try and send it back. You have a hatchback. They probably sent you a catback for the 4door model. Ive seen this happen with EG's a few times.
    If you cant send it back, take it to an exhaust specialty shop and have them cut it and re-weld it for you.
  5. HATCHET_HONDA
    hobart, indiana
    well i took the mid pipe to usa muffler down the road from me..... the guy did a really good job re -welding the flange to the pipe after it was cut off to length and the hanger moved. megan was no help..no response to emails and they didnt answer the phone. the ebayer i bought it from just said to call megan so i didnt bother sending it back to them...so far its bolting up ok but i need a flange gasket near the cat.
  6. LS_VTEC
    NJ
    Just use a spring loaded flange. The exhaust shop will sell you one, but will probably charge you a lot. Goto AutoZone or Pep Boys and try and find one there.
  7. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    My Skunk2 bolted right on with a perfect fit.
  8. HATCHET_HONDA
    hobart, indiana
    i couldnt get that lucky....anything ive ever bought has always had a fitment issue...interior, body parts, electrical, suspension, now exhaust. i always seem to get the bone
  9. LS_VTEC
    NJ
    Stop buying parts from eBay. :)
  10. khrisb
    khrisb ******
    skunk2 is baller expensive too...
  11. 91_civic_si
    Wasilla, Alaska
    You pay for quality. Be smart and do it right the first time.:rolleyes:
  12. Sko0terMan
    Sko0terMan Member
    Los Angeles
    megan racing is down the street from my shop. they always seem busy with car going in and out of their shop. I have bought some other things from them and never had a problem with them. I put one of their exhaust systems on my friends eg and it went in no problem.
  13. HATCHET_HONDA
    hobart, indiana
    prolly a good idea..but i always buy products from reputable companies...i dunno..but exhaust is installed, just need the flange gasket and im good. dammit! i bet that skunk2 sounds good too
  14. Uncle Buck
    Uncle Buck JDMDecals.com guru
    Spearfish, South Dakota
    i wouldnt say its Megan Racing's fault..... cus as stated by someone above, you never know what kind of exhaust work someone had done prior.... Megan used a STOCK setup and used its measurements from there..... so unless you can verify that its stock, untouched then you might have a leg to stand on..... ive ordered alot of parts from Megan and never once have i had issues.....and i do purchases thru them for all sorts of cars that have come thru our shop...
  15. HATCHET_HONDA
    hobart, indiana
    well the only exhaust mod i had already was a 4-2-1 header...which bolted up to the rest of the exhaust perfectly. bought a direct fit cat cause the old one was welded onto the pipe. all stock piping...one thing i did see tho was the rear hanger on the body under the lip on the bumper had been broke off.
    im sure this kit wasnt intended for a hatch..explains why it was longer in the middle while the rear section fit ok
