90crx si d16z6 swap question about IM
Discussion in 'Civic and CRX - EF' started by deejay, Aug 5, 2006.
  1. deejay
    deejay Junior Member
    Well i'm goin to be doin a d16z6 swap into my 90crx si ive got the rywire obd0-obd1 harness and vtec harness. but someone has mentioned to me that it will be better to use my old intake manifold from my old motor for wiring purposes is this true? thx for any replies
    DeeJay
  2. deejay
    thx for the reply
    thanks for the reply BLANCO
    DeeJay
  3. deejay
    I have my a6 motor out and gonna put the z6 motor in tomorrow and replaced my t-belt and put the drivers side motor mount on and was wondering which t-belt covers did you end up using did you just modify your z6 covers?
    thx
    DeeJay
  4. deejay
    Damn i didn't notice my z6 motor didn't come with the bracket from the intake to the block gonna have to look around for one thx again for the help blanco depining the injector plugs was pretty easy, what did you do when you removed the resistor box? did you just solder the 5 wires together?
    deejay
  5. deejay
    whats the OBDI injector block off plug?
    Deejay
