Hitlist Motorsports
Ok so i got a 90 SI and want to know what motor you guys think will be best for all around racing. My first option is to buy a wrecked Type R integra and use the B18C5, if i do that what am i going to need, i know its not going to be a straight up bolt in. and also would i be able to use the 4 wheel disc brakes and is that a bolt in?
If i dont go with that what about a B16 of some sort, im tryin to get vtec and a plan on rebuilding the motor with low comp pistons and rods, valves and springs, cams, skunk 2 intake manifold, 550cc fuel injectors. and whatever else i can afford. what is going to be the best swap for all around racing, but practical enough to be driven on the street. Is the Type R swap even possible?
Thanks
Thanks
