91 accord h22 5 speed swap issue....PLEASE HELP!!!
Discussion in 'Accord' started by sway, Apr 9, 2010.
  1. sway
    sway New Member
    I just got through having a H22a swapped into my 91 accord. We also did a 5 speed swap and the issue we are having is that the shifter cables are a few inches too short. We went with a 91 f22 tranny being I do alot of highway driving. The cables we are using are from a 92 accord and the same with the shifter. we tried some CD5 cables but came up with the same issue.....can anyone help please? Do I have to have prelude cables and shifter rather than the CB7 ones???? (heard they were a lil longer):confused:
  2. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    thats odd. im not that educated on this swap but on my 94 accord I used the accord cables.
  3. civichatch1988
    civichatch1988 Ef hatch
    Seattle
    you should be using the prelude cables i do believe at least thats what ive been told
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    sounds like you got the motor in there wrong, the linkage should fit fine
  5. sway
    sway New Member
    ok well I got the cable issue done...however, ....the H22 is running really rough and Very rich. The guy that did the engine thinks someone put f22 injectors in it....(which would explain alot), however, if that isn't the case....do you have any ideas what it could be? It almost sounds like it is running on 3 cyls or something.....it still has a little of the cheap gas that was in it when my f22 died.( i know that is bad for a high compression H22)...and one last thing, After running it for a lil bit I noticed that the cat was glowing red. ( messed up to have this many issues with my new engine huh). Where should I start lol....
  6. powerdriverh22
    spfld, mo
    you have a clogged cat or something. the cat should not get that hot under normal running conditions. if it has f22 injectors in it, it will be running lean not rich.
  7. AHHVTEC
    Alabama
    what ecu are you running, and check to make sure all 4 pistons are firing
  8. sway
    sway New Member
    I'm running a p13....got that all figured out now. The guy that installed the engine had the distributor firing in wrong order which fouled out 2 new plugs....
  9. sway
    sway New Member
    HOWEVER all of a sudden my key wont come out of the ignition. It WAS an auto and swapped to a 5 speed. I got frustrated when I couldnt get my key out and just disconnected the positive from the batter so I wouldn't kill it and when I did that I heard a click. I went back to my key and it came out fine.....tried it again and same procedure had to be done to get the key out....any suggestions?
  10. AHHVTEC
    Alabama
    buy a new switch lol, 25 bucks autozone
  11. mightymouse787
    mightymouse787 New Member
    91 wagon project
    i have a 91 accord wagon and want to do a engine swap for power but can't decide to go with the h22a or the V6. can anyone give me some advice? :confused:
  12. BrutalB83
    Rochester Hills, MI
    1.) Next time, start your own thread please. There's no need to butt in on somebody else's question.
    2.) The H22 is your only choice. The V6 is MAYBE do-able, but it would be a first-of-it's-kind, totally custom type of thing. The 90-93 Accords never came with a V6, so the bay is not set up for it.
    Like I said, if you have more questions you should start your own thread. Just go into the forum where you want to place your thread and click the "New Thread" button at the top left...
  13. 22deuce
    22deuce New Member
    check your o2 sensor
