Which obd is my accord?? I am thinking about swapping in a f22b which has a obd1 in it, and I know that I will have to change the harness and ecu into an obd1 compatable unit. Would I be able to just take a obd1 harness and ecu out of any random car and transfer it to mine? (If I only have an obd0)
keep it obd0 unless you have a really good reason for switching. You can swap the motor and use the electronics ( injectors, distributor, ecu, etc.) that are already in your car on the new motor, no big deal.
