Mr.Hankey
So my co-worker drives a 91 honda accord. The power locks do not work.
Iv checked the Fuse is good.
I can hear what i think is the Solenoid (on drivers side) it clicks when i press the power lock on the passenger as well as the driver side down or up.
Another Co-Worker suggested it might be the relay for the switch.
So my questions is what do you guys think? if u think its the relay then where are the relays located in the 91 accords? Also do they have a relay per switch or a single relay so that i can check it?
Thanks
Thanks
