91 accord w/ h23 giving me a head ache
Discussion in 'Accord' started by PortLuver, Mar 17, 2011.
  1. PortLuver
    PortLuver New Member
    Bx
    :confused: Engine code of 6 which is engine coolant temp switch which operates the injector timing. Car starts every once and a while runs for a while then cuts off and won't restart. I have changed the sensor several times, swaped computers replaced dizzy, and problem still persists.
    Could this possibly be a ground issue.
    All comments are welcomed
    Lead, follow or get out of the way!!!!
  2. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    well there are two different coolant sensors there, did you try both of them, and check wiring
