91 b16a swap. few questions before i proceed
Discussion in 'HYBRID -> ED-EF / DA' started by integraboomer, Aug 31, 2011.
  1. integraboomer
    integraboomer New Member
    Alright swapping over b16a into a 91 ed
    This is what I have done:
    -dpfi to mpfi ( accidentally got the inj numbers backwards. No biggy)
    - converted all obd0 plugs on the harness to obd1.( dizzy,alt,injector clips fit)
    -dropped motor in hole everything mounts. No clutch in the tranny. Going to start it first to see that it runs ok. Current clutch is junk anyways.
    Still need:
    Obd0 to obd1 jumper
    B series axles
    Fluids
    My questions: I no it is said there are some plugs in the stick dpfi harness that won't be used. But where the knock sensor is located there was a plug that fit. Is this incorrect? Do I need to add this to the harness?
    2: for the 4 wire o2 sensor do I just run the wires from the provisions in the jumper to the sensor? Also will this setup only use one sensor? If so will I not use the stock one wire? I noticed my obd1 gsr header has two single wire sensors? That will be the header I use st first.
    Any help on this will be appreciated. Thanks
  2. integraboomer
    Come on anybody?
  3. dirt
    dirt New Member
    ah, the jumper harness will have the wires for the o2. If it's obd1 it will have 4-wires for the o2. To me it sounds like somebody swapped that header into a car and kept it obd0. You'll need a different o2 to run obd1. Obd1 only has 1 o2 sensor and obd2 has two I believe, but they wouldn't both bee on the manifold, one would be near the cat I think.
  4. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    OBD1 has one primary O2
    Knock sensor and plug will need to come from the B16 and you will need to run a line into the cabin so it can be hooked up to the ECU. Maybe the jumper hanress has a wire ready to atttch to the knock sensor? If you are running a virgin ECU then you need the knock hooked up. It can be deleted with a chipped ECU
  5. integraboomer
    Ic so even a p28 looks for knock sensor?
  6. rcoolb2002
    rcoolb2002 Member
    Maryland
    No a p28 doesn't use a knock sensor, but its a d16z6 ecu, still requiring chipping to run a b16 properly.
  7. integraboomer
    what kind of chipping or changes?
  8. rcoolb2002
    rcoolb2002 Member
    Maryland
    Easiest is to just find a p30 and run the wiring for all the sensors. Or you will have to get a p28 that is chipped for a b16. If you want it to run its best.
