91 b18a1 into a 93 civic coupe
Discussion in 'HYBRID -> EG-EK / DC' started by jasonLScivic, Oct 19, 2010.
  1. jasonLScivic
    jasonLScivic New Member
    Hello fellow peers ok I need some help I just got a b18a1 from a 91 tegy.I want to swap into a 93 civic coupe... can u guys tell me wat I need to do this swap without paying a lot.(I knowi get wwat I pay for) but give me a break budget is hard right now ... I heard if iget all the mounts from a 99/00 civic SI I wil be good with everything fittin including the linkage...well needs some info will appreciate it ok thanks for looking hope to get some feedback soon
  2. 99sidude
    Ohio
    You need the mounts from a 94-01 integra. You will also need a cable -->hydro conversion kit if you plan on running the DA transmission.
  3. jasonLScivic
    Yeah im planning to dothe conversion but if i get the mounts from that year of the tegy thay fit? wat bout the lshift linkage? and can i use the stiock harness? i was running a d16 mini swap... thanks for the help hope to get some more feedback
