'91 B18B in '99-'00 Civic EX
Discussion in 'HYBRID -> EG-EK / DC' started by DiSbaDbOi, Nov 13, 2003.
  1. DiSbaDbOi
    DiSbaDbOi Junior Member
    I have a 99-00 civic ex and I was planning on doing a '91 B18B motor swap. But I have no idea what kinda wire harness, mounts, and ecu to use. I done a search but I couldn't find nothing that I was looking for. Can some tell me or show me a site that has all these information. I would like all these information ASAP. Thanks~!!
  2. E_SolSi
    that engine will be a BITCH to get wired in there.... and the tranny wont work
  3. DiSbaDbOi
    is it really that bad? I know the tranny won't fit, i'm getting a hydro tranny.
  4. 92civicb18b1
    92civicb18b1 The Trisexual
    It isn't hard until the wiring part comes along, and in 91' they had a b18a1 not b18b1, BTW if you haven't already bought the engine, DON'T BUY IT. Buy one from a 96+, then it should wire up fine, and bolt right in (correct me if I'm wrong)
  5. DiSbaDbOi
    Yea, thats why i post this topic, because i have no idea how to wire everything. and yea I had already bought it.
  6. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    sucks man, pull the intake mani, and buy a new one from a 96+ integra, no you can't use the one that came on it. you also need to use your stock wiring harness, but you will have connectors that wont go anywhere because your harness is for a vtec motor.
    wait i'll make you a list of things you need-
    intake mani from a 96+ teg.
    throttle body from a 96+ teg
    tranny from a 94+ integra or a 92+ civic del sol VTEC (only the VTEC model, no s or si)
    you will need all the sensors from your old motor, and your old engine harness.
    if you live in a smog state you wont pass because the block is too old.
    you will also need the mounting hardware from a 96+ integra gsr.
    shift linkage from a 94+ integra
    your stock injectors will wok fine too, so you need those.
    thats all i can think of right now, but the intake mani and throttle body are non-negotiable, you have to replace them, and you will realy want to use your stock harness, and if you can get an obd2b- obd1 conversion harness and find an obd1 pr4 or p75 from a manual tranny integra.
  7. DiSbaDbOi
    thanks saturn_boy, that was a hold lot of information you gave me. What do you mean by vtec only tranny? Can't I use any B-series hydro tranny? Also, what mounting hardware from 96+ gsr?
  8. freshclive
    freshclive Junior Member
    he means just that not all del sol's are b series only the 94-97 del sol VTEC(b16a2,3),
    rest are all d series. ;)
  9. DiSbaDbOi
    Oh I get it, but I still need more information about the topic. Thanks
  10. saturn_boy96
    Sheridan, WY
    you need the motor mounts from a 96+ integra gsr, or a has port mount kit.
    i think you will also need a lower divier side motor mount bracket from a 96+ integra gsr.
    freshclive: thanks, thats exactly what i meant.
  11. MaliWho97
    MaliWho97 Senior Member
    Plus, its Illegal to put a motor from a lower OBD Bracket in your vehicle. Example, OBD2 car w/ OBD1 motor, illegal. OBD1 car w/ OBD2 motor, legal. Get me???
  12. saturn_boy96
    Sheridan, WY
  13. DiSbaDbOi
    People have been telling me I need 99-00 civic si motor mounts, besides the a/c bracket..i need the 96-97 del sol bracket.
    What do you mean only in smog states? I live in Calfornia
  14. E_SolSi
    if your in calli and you try to swap that engine in that car they will castrate you
  15. DiSbaDbOi
    will it still be illegal if i swap that motor in but with a vtec head? does it make any difference?
  16. E_SolSi
    the Peoples Republic of California doesnt allow head swaps
  17. 92civicb18b1
    That sucks man, You can't drive your car legally in California with that motor. But you might be able to trick them, get the block restamped, use ALL obd2 parts (including the head), and make sure you'll pass emissions. Or you can just buy an EG and drop it right in.
  18. hondapwr
    hondapwr Junior Member
    for one, if you are smart and want to save money, go to hasport, pick up a Cable Tranny Conversion kit for like 130 bucks, then pick up a 90-93 tranny which will cost you like 1/3 what a hydro tranny will. You need the rear tranny mount for a 99-2000 civic si. You need linkage from whatever series tranny u use. wiring won't be easy, but you can always consider an obd1 conversion harness which can be purchased from skunk2 which will also allow you to save some serious dough. You should try to get in with some guys that live near you that can help you with the swap. It won't be easy and I would suggest getting some help from someone more experienced. Everyone knows someone who knows someone that can swap honda motors for CHEAP.
    Jason
  19. InsaneCivicSedan
    InsaneCivicSedan Junior Member
    Tampa,FL
    I believe the 91 LS was a b18a... the b1 was from 94-95 in obd1 and 96-01 which is obd2.... to use the B1 in your car all you need is mounts from a 99-00 si and it will bolt right in and plug n play.... only wires you dont connect are vtec (of course)......
  20. DiSbaDbOi
    what do you mean plug n play? I can use my wire harness off my SOHC for the LS motor?
