91 Civ B16a Cai
JrSiRb16A
sup..91 Civ w/B16A..what CAI application will fit without modifaction..
Model for the Car..or Model for the Motor..please help..
99-00 si if you want a 3" pipe... 88-91 CRX Si if you want 2.5"
Your choice, they both fit with a little encouragement.
newer civic cai wont work cuz they dont go down the hole by the fender and it wont work.. 88-91 civic/crx si should work.!!
If you get the 99-00 SI intake you have to move your battery and it will work if you don't want to move your battery go with the CRX Si intake instead. I've done both to my car and there isn't much of a difference in power between the two, I just needed the room to put my ignition so I moved the battery and have the 99-00 intake.
