Is there an access hole to get to the fuel pump on these cars or do I need to drop the gas tank. I know I needed to drop the tank on my 91 CRX but not sure on a 4 door civic. any help on this would be great.
gotta drop the tank but lucky for you the civic gas tank has a easy to find and access drain plug. Drain the gas if you have any? maybe why won't start. Drop the tank 2 13mm nuts use deep socket. unplug install plug back in hang fill with gas. Took me like 20 min to put my new high flow pump in. good luck
