If your using obd1 injectors, you don't need the resistor box but you will need to convert it to obd1. Change the injector clips to obd1, obd1 distributor, obd1 jumper harness and a stock p28 for manual transaxle if your keeping the harness that is in the car. You may have to wire in a couple sensors as well.
