91 civic DX swap! Help?
D16a
D16A
Hey all, I want to swap a D16A (equal to Ex/Si 92-95) into my 91 civic dx. I wanted to know if it was possible? Here is a list of what I have
Parts:
92-95 motor (with complete engine harness)
P28
89 Si tranny (keeping it cable)
89 Si dash harness (recked CRX Si)
I'm also getting a obd0-obd1 jumper harness. Will it be a plug and play after I put in the Si dash harness in? Let me know what is the best route I'm open for suggestions.
Quoted post[/post]]
Parts:
P28
Youll need to rewire the engine harness to fit the OBD0 plugs or adapt the dash harness to fit the engine harness
Thanks for the info guys! I actually was thinking of just swaping the dx dash harness with the 89 Si harness and than swaping in the D16A using a jumper harness. But i'll try to do some rewiring as well to make sure everything works. I'm sure the wiring won't be hard. Also it's not a Z6 going in it's a JDM D16A from what I've researched
this is the engine you have, correct? if so, it is the same as a D16Z6
Quoted post[/post]]
Yes it is. I've already mention that in the pervious posts. I wonder if it's worth doing, I mean this Dx motor has over 266,000 miles on it. And I just need something reliable to commute to work.
It's well worth it. Im actually doing a similar swap on my 90 civic DX HB. Only difference is that I will be installing D16Y8. As for wiring Im going to stay OBD-0 hence the z6 Intake manifold. So all i have to do is convert DPFI to MPFI no resistor pack needed. plus the OBD-0 distributor fits with no mod on the Y8 head.
Good luck on your setup. Here's my setup if you need more info
https://hondaswap.com/forums/index.php?showtopic=69739
