91 Civic fuel pump removal?
Discussion in 'Civic and CRX - EF' started by sleeper1.6, Jul 22, 2008.
  1. sleeper1.6
    sleeper1.6 Member
    I have a 91 Civic that won't start. It will turn over but it just won't start. I can't hear the fuel pump prime at all, even when I pulled the back seat up. But any way I tried to take the fuel pump off to see if it was doing anything, but I don't know how to take the pump off. So any info at this time would be great. Thank You.
  2. efhondakid
    Akron-Canton, Ohio
    How do you know its the fuel pump? It might be your main relay. But to get to the fuel pump you have to drop the tank.
  3. sleeper1.6
    sleeper1.6 Member
    Well we pulled up the back seat and it's right there. And on the 92-95 civic it's the same way.
  4. efhondakid
    Akron-Canton, Ohio
    That cover is for the sending unit, the acutal fuel pump is about 8 inches behind that, you have to drop the tank to get to it trust me.
  5. sleeper1.6
    sleeper1.6 Member
    Well damn, the main relay you were talking about how would I go about fixing that? I don't mess with fuel pumps and wiring that much as you can tell. Oh and it can't be a fuse I checked that.
  6. the.original.kermit
    the.original.kermit I know everything
    Hamilton, MI
    Or run live 12 V to the pump. If it doesn't run, it's bad. If it does it's something else.
    If it's the pump, I would suggest that you take it in. Even for more experienced mechanics, tanks can cause headaches as the lines are almost always rusted to piss. Same with the bolts. Speaking from Michigan that is, if you are south, that's probably going to be different.
  7. sleeper1.6
    sleeper1.6 Member
    I'm from the south, I don't have rust problems. But the cars has been sitting around for 2 years. I'll try the 12v battery idea. Thanks a lot.
  8. sleeper1.6
    sleeper1.6 Member
    Ok, I took my NRG Nano performance battery to the plug and there was nothing. I didn't "plug" the wires in I just took them and touched two open wires to the male plug. Would that work or would I have to cut the female plug and make a new one?
  9. the.original.kermit
    Hamilton, MI
    I'm assuming that's a car battery...
    Yeah, as long as it's charged up good and you are making good contact, it should have fired up
  10. sleeper1.6
    sleeper1.6 Member
    Yes, it is a car battery, but it is small and I mean small. It looks like a motorcycle battery. Like 9 lbs at 180 AMPs.
  11. the.original.kermit
    Hamilton, MI
    yeah, it should work, probably time to get that pump replaced
  12. sleeper1.6
    sleeper1.6 Member
    Thanks a lot man. Well time to drop a gas tank! :)
  13. the.original.kermit
    Hamilton, MI
  14. sleeper1.6
    sleeper1.6 Member
    Well got the old fuel pump out, and boy does it look like crap. It has rust all over it, from top to bottom. I hooked it up to a battery and it did nothing... it's dead. Were going to drain all of the gas tomorrow, and go from there.
  15. the.original.kermit
    Hamilton, MI
    LOL, wow, obviously you don't live anywhere close to me. On a 15/20 year old car, you might as well kiss any fittings on the fuel/brakes goodbye. It probably would have taken me several hours to drop the tanks on my CRX. The strap bolts are so rusted that I doubt that I would be able to get them withoug breaking or cutting them.
    Well goodluck, also, why drain the gas and replace the tank... just replace the pump. I believe this one should work for your application.
    eBay Motors: NEW FUEL PUMP OEM 1988-1991 HONDA CIVIC (item 160191120063 end time Aug-11-08 17:26:38 PDT)
  16. sleeper1.6
    sleeper1.6 Member
    Oh I'm not replacing the tank itself, just the pump. We're taking the old gas out. I did that at first but didn't get all of it out because we didn't jack the car up on the front left hand side. But thanks for the fuel pump price on ebay.
  17. tommytoo
    tommytoo New Member
    91 Honda civic sedan
    I Need to remove my gas tank to get to the fuel pump out For some reason. Im not getting any fuel pressure. Would it be my fuel pump Maybe Ive been trying for 2 weeks to get it to start:confused:
  18. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    Can you post a picture of the top of the tank itself? I have a '91 hatchback and read somewhere they put an access cover in the later models so you don't have to drop tank to access fuel pump for maintenance.
    As such, I am planning on cutting and installing an access cover in the '91 hatchback. Just need to see a tank to know exactly where it needs to be.
    Fuel pump works ok, but I have a higher performance aftermarket pump I want to install as preventative maintenance.
  19. Fernpatch
    Fernpatch Member
    Bellingham,WA
    on my brothers 91 civic si I had to drop the tank to access the fuel pump. There is an access hole under the rear seat but it only allows you to disconnect the pig tail from the pump hanger.
    Dual: I think I still have a spare gas tank in my storage. I will see if I can find it and snap a pic for you.
  20. Dual-500
    Fort Worth, Texas
    ^ Thanks man - it should save me some pain. I have looked at a few pictures of "replacement tanks" and they show the fuel pump to be driver side on top and full aft, full left placement. Want to be sure before I cut.
