'91 Civic Hatch Si W/ D16a6
Discussion in 'HYBRID -> EG-EK / DC' started by captainbad, Jan 29, 2003.
  1. captainbad
    captainbad Junior Member
    I'm rather new to the topic of swapping engines so please forgive my ignorance. I've read a lot of posts and have yet to find a consensus on what is the all around best swap for a 4g w/ D16A6. By 'all-around' I mean: price, ease of swap, power, torque and future mods. I decided I wanted to keep my '91 Hatch as a fun, relatively street legal ;), non-race car; but fast & powerful too. I've 156k on this lil sucker and she still runs great but she's been worked...hard. ;) I really don't think she's got much left to give. I haven't heard much good about D series anything. Sooooo, gentlemen, any assistance that you could provide would be greatly appreciated. In the meantime, other than increasing airflow ( intake, header, exhaust) are there any other tweaks ( not NOS or Turbo) that I can impliment to squeeze more power & torque out of her? Chip? Cam? Cam gear? Under drive? I don't want to do too much to the top end and lose the bottom before I can do the swap. Thanks in advance!
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    So el capiton,what are you looking to spend on this here swap?
  3. captainbad
    I venture a guess of 1-2g's but I'd like to get a good balance of the 'all-around' criteria in the original post. A 'most bang for the buck' scenario.
  4. xj0hnx
    C.C.TX.
    B16A1 siR is good for that then.The mounts needed can be bought for aroud 300-499 depending on how hard you look,I've seen some recently for 250.The changeover complete should run about 1150+300 or so shipping+mounts would leave you 200-300 to play with if something comes up and for little extras like fluids exhaust refitting etc...Or you could get a b18a or a zc,but IMO you'd be happier with the B16 for your purposes.
  5. captainbad
    Thanks B. I called a local shop that get's low milage engines from japan. They say they'll do the JDM ZC for the D16 for a g out the door. Not really any great power change but I'm learning that my rings are more than likely collapsed and a new engine is a must.... :angry:
  6. xj0hnx
    C.C.TX.
    Is that the install or just the motor?Make sure it is the DOHC,the SOHC are pieces of shit.
  7. captainbad
    Though I didn't ask that question directly, I got the distinct impression that it was the motor & install. Is the ZC dohc or sohc? isn't the dohc a z6?
  8. red95solsi
    red95solsi Senior Member
    Kansas City Missouri
    z6 is sohc vtec zc can be sohc or dohc non-vtec
  9. xj0hnx
    C.C.TX.
    There are way too many different "ZC" motors to say they are this or that.Most of what gets called ZC is Labeled D series here in the states.
    Ask this question directly.Get it in writing.
  10. captainbad
    Thanks red I checked a web site and you are correct sir! The cool thing is, if I do this particular swa (D16A6 out, ZC in), I get +/-30 hp jump with out my bolt on's. That is appealing to me. :D
  11. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    Dude, if u want power. u cannot beat the LS, its the most poweful engine in ur pricerange. Torque power is alot more fun than Vtec power IMO, u can always get good top end with vtec or turbo or nos, but u cant get a B16a with the same bottem end as any LS. i got my LS for 2000 complete. and with i/e i smoke most cars in my area no problem.
  12. xj0hnx
    C.C.TX.
    A B16A1 complete can be had for $1150 and the cost of mounts and will be doing better than a LS.
  13. SleEPeR_CRX
    dude, u got it for 1150 US+mounts. thats like 3200 canadian. and i doubt thats full swap. i looked into it here, and had it all ready. mounts 400 engine 2300 linkage integra rear mount and all that would easily be over 1000 bucks more. so compare 3200 ( canadian) for B16a or 2000)canadian) FULL SWAP for b18a. and ive riden and drove in b18a ZC and B16a civic's/crx's before i made my choice on swap. the torque from the B18a is more pratical in everyday driving, will beat any B16a from 0-60 and will only lose after that do to lack of vtec. who cares about a race after 100 anyway. trust me man b18a is way to go.
  14. captainbad
    Ok, I've done some research and here's what I came up with: For me, for now, the ZC DOHC is the motor of choice. To do anything else will at minimum +/-$400 just for the mounts and untold incidentals. I'm intent on doing a ZC/Si tranny hybrid (which I've read is a kick ass combo for this set up; I believe uses the front 1-5 from a ZC and the final from an Si) I also know that by using the DOHC ZC I'll need a new hood (which is ok since a unavoidable bouncing tool box on the freeway wiped the current one); I have a choice of 3 ECU's: the stock Si, 88-89 teg, and the ZC. They all plug straight into the wiring harness and are all OBD0 or preOBD? right?; and some minor doctoring of the distributor plug from round (1- 7 pin) to square (2- 1 5 pin and 1 2 pin); I'll need to port my 4-1 Mugen style header flange about 3mm with a die grinder to fit the ZC manifold. Have I missed anything guys?
    I'm doing this swap because I suspect, which I believe a compression leak-down test will confirm, my head gasket is partially blown allowing water in to one or more cylinders or, a cracked head and/or block ( I think the latter is unlikely- the overheat (due to a cracked piece of crap stock radiator) wasn't THAT bad; and, I may have collapesed rings (I'm burning more oil than Honda states is normal- something like 1Q/k mi. for higher milage engines such as mine)....so anyway, im curious, are the SOHC and DOHC head interchangable on the ZC block?
  15. xj0hnx
    C.C.TX.
    You obviously haven't raced any B16's,I'll take your b18a apart with a B16.And "who cares about a race over a hundred?In the 1/4 it is who can get going how fast the fastest buddy if your motor tops at 100 and I got 27 more miles an hour guess what?You lose.Do some research before you start advising people what will blow what away.
  16. SleEPeR_CRX
    Dude, personally when i drive i dont use 120+ normally. nor can my car do it on the 1/4mile, b16a's have a great feel but can never make up torque, where a B18a can always make up hp. ive driven both man,and the b18a is a way better feeling engine
  17. xj0hnx
    C.C.TX.
    I'mnot saying a motor with more torque doesn't feel good,just don't be making statments like a B18A is "always" going to beat a B16 0-60 because it doesn't,vtec isn't a makeshift turbo that dominates the world,but the 16 makes more hp and does it faster.
  18. SleEPeR_CRX
    agreed. i know a b18a wont always, but take a b18 and a b16 with i/h/e and the same driver. the b18a will pretty much always beat it 0-60, which is pretty much the only kinda racing that people do in town. 1/4 mile i know the b16a will beat it, but in normal daily driving u cant get going that fast anyway.
