91 civic si to a b16a1
Discussion in 'Civic and CRX - EF' started by tylerf1000, Sep 26, 2006.
  1. tylerf1000
    tylerf1000 Junior Member
    ontario, Canada
    I just had a a couple of pre swap questions
    I'm swapping a b16a1 into a d16a6
    Is the stock intake and fuelpump good or should they be replaced???
    Will the headers i have for the d16 fit onto the b16???
    Also will the stock axles work, or do i need new ones??
    will the b-series mounts bolt right onto the 91 civic si, or is modification necessary???
  2. ef8
    ef8 Junior Member
    By stock intake do you mean the intake manifold?If so,no it will not bolt up.
    The fuel pump will be ok.
    No your header will not bolt up.
    Yes you will need 90-93 integra axles..(preferably 90-91)
    Stock mounts will NOT work.You need to buy aftermarket b-series into an ef mounts.
  3. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    your an idiot.
  4. tylerf1000
    ontario, Canada
    Whats your problem bud??
    You got something to say??
  5. Andrew
    Tallahassee, FL
    Ohh. no.. not you..
    Thats who I'm calling an Idiot.
    Your looking good. GL on the swap, sry for the confusion!
  6. Concept:Ef9 si-R
    Concept:Ef9 si-R New Member
    El Paso Texas
    WATS UR PROB SON? wHY U hATiNg?:eek:
  7. Andrew
    Tallahassee, FL
    For that reason exactly.
