Originally posted by Calesta@Jun 11 2003, 04:45 PM
Guys- get your information straight first before blabbing all over the place.
You can't use the original ECU because it's set up for two injectors, not four. It doesn't matter that the original engine was SOHC and the new one is DOHC (if that's the ZC he chose)- the ECU doesn't control the cams.
The sedan transmission (DX and LX) are the exact same as the Si transmission except for the final drive. The sedans have a 4.058 final drive while the Si has a 4.250 FD. Gears 1 through 5 are the same. You can read that information in your Helms. The 1.5L engines in the 4th generation Civics came with 3 or 4 different transmissions, so make sure you know what you're talking about.
1.5L 4G Civic transmissions:
HF
STD
DX hatch
DX/LX sedan
They're all slightly different. You can't just say "D15 tranny". There was more than one.
The sedan transmission isn't bad at all- it just has a slightly taller final drive than the Si, so you'll lose a bit of acceleration but recover some fuel efficiency. It's a really good middle ground between the Si and the tall FD of the non-Si hatch transmission.
