91 CRX Brake Swap
Discussion in 'Civic and CRX - EW' started by Yurik, Apr 6, 2007.
  1. Yurik
    Yurik New Member
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    The 90-93 integra brakes are plenty for a CRX. Anything more is pretty much overkill(you don't need that much brake to stop a light car).
  3. Yurik
    Yurik New Member
    well then in that case, is all i need the caliper, pads, and rotor for that swap?
  4. 801CRX
    801CRX Got Rice?
    UTAH
    No you need the trailing arm too.
  5. Yurik
    Yurik New Member
    im talkin front not rear
  6. Yurik
    Yurik New Member
    if i did rear i would need trailing arm, ebrake cable, as well as the brake components, but im wanting to do the front
    do i jus need the caliper, bracket, pads, rotor?
  7. K2e2vin
    Raleigh, NC
    you need the knuckles too.
  8. Yurik
    Yurik New Member
    ah man that sucks, does that mess up your alignment/steering or is it the same adjustments as the stock knuckles
  9. K2e2vin
    Raleigh, NC
    I believe its a tad taller but nothing noticeable. If you want the stock geometry, go with the 90-91 4-door Civic EX knuckles and brakes. The brakes are the same size as the Integra's but the knuckles have the same dimensions as the other EFs; and are lighter than the DA Integras. :).
    1 person likes this.
  10. Yurik
    Yurik New Member
    nice! +rep
    so basically my options are the integra brake swap which consists of:
    calipers, pads, rotors, knuckles, caliper brackets
    the civic swap, consisting of the same components
    or the accord wagon swap, with the accord wagon bracket, caliper, pad, with the 91 civic EX rotor...what is the advantage to running the wagon caliper with the civic ex rotor? obviously it has a stronger caliper, but how in the world do those match up
  11. K2e2vin
    Raleigh, NC
    The Wagon caliper=ITR caliper. It's bigger; made for the 11.1" rotor but when you put it on a 88-91 EF(minus the 90-91 EX), it fits the 10.3" rotor. It accepts a larger pad.
    IMO, the Wagon/ITR caliper is overkill for the EFs. The Integra or Civic options are your best bet. Some people have great results with the stock 9.5" with just switching to different brake pad compound. Only reason to upsize the rotors is if you're suffering from brake fade(usually road course cars). If you drag race, definitely keep the stock 9.5" front brakes.
  12. Yurik
    Yurik New Member
    thanks for all the information man, i love drag racing, but i love corners and stuff 10 times more, the civic swap sounds the best, ill jus have to get my hands on a set of knuckles
