91 Crx...locks
Ted O
Was wondering what I needed to replace all the locks, to use one key, like the ignition, doors, and hatch? Can i pick these up as a set? or is it basically not an option? Thanks
You need a new set of tumblers all around a keys to match. You may be able to find them new from honda or from certain locksmiths. Try junk yards if possible for used ones, or ebay. It isn't hard to replace the doors and the hatch. You can probably do both doors in a couple hours if your fast. Havn't tried the ignition tho.
Quoted post[/post]]
Alright, anyone on the forums know how I can get ahold of that stuff? Thanks
when my car got stolen they broke the steering column so i had to replace the ignition on it. the locksmith charged me $13 to change the tumbler so my old key would work on the new ignition. just go to a junk yard and pull off all the locks on the car. the key code to make keys is on the door and trunk locks.
