91 CRX Occasional Jerking in First Gear
Discussion in 'Civic and CRX - EF' started by resopaton, Jul 28, 2010.
  1. resopaton
    resopaton New Member
    Hi,
    I have a problem with a stock 91 CRX HF I just purchased. After disengaging the clutch and accelerating in first gear the car will begin to jerk. The more gas I give it the more violent this jerk gets. Once I engage the clutch it stops. This only happens about 35% of the time and only in first gear, wether idle or accelerating to shift into 2nd. If I release the clutch super slow, while increasing my RPM's to 2K I can get the jerking to go away but at the same time the car will nearly stall.
    At first I thought clutch, but after doing some reading on the forum I realized that it might be a motor mount.
    Any more insight to my problem would be much appreciated?
    Thanks in advance!
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Probably worn torque mounts. My brother's car did this when we didn't install the two torque mounts on his 93 Civic(not to mention his rear mount was pretty beat up). My 92 Accord does this a little(worn mounts).
    On my Civic and CRX I got rid of my front torque mount(due to aftermarket front crossmember) and used Energy Suspension mount insert on the rear torque mount. It vibrates a little more but not very noticeably and never had any jerking issues.
  3. resopaton
    Thanks for the input!
  4. resopaton
    Ok, so I found the front motor mount to be completely shot. I replaced it but the problem is still persists.
    Any other thoughts?
    Anyone?
  5. K2e2vin
    Raleigh, NC
    Did you check the rear mount? I didn't think about this earlier; but maybe worn suspension bushings too?
  6. resopaton
    Both the rear and the side appear to be intact, but I might replace them. I will check the suspension bushings first.
    Thanks again!
