91 crx: one more question
esears
ok im about to swap over the engine. i need to know if i can just use my del sol transmission, that is already on the engine, to put in my crx. i know the del sol tranny is a hydro and the crx tranny is a cable. will it work? what should i do?
If you want to run hydro, you'd need a conversion kit like what Hasport sells. If anything I'd try to pick up a cable d-series transmission, shouldn't be too expensive. If not that, try to trade your hydro transmission for a cable transmission.
Just get the HA Sport conversion kit since you already have the tranny. All the parts are a direct bolt on. It's very simple to install. I have one. It works great.:bow:
