91 crx si with b16 swap need help a.s.a.p
Discussion in 'HYBRID -> ED-EF / DA' started by JustoEny, Jan 6, 2011.
  1. JustoEny
    JustoEny New Member
    whats good i just finshed doin the wiring to my car for the b16 swap with a obd 0 pr3 ecu, i ran the knock sensor and the o2 sensor and the 2 vtec wires but when i started the car it runs fine but the check engine lights on and the ecu is reading 4 crank sensor which is in the dizzy but theres nothin wrong with the dizzy please someone help me out:rimshot:
  2. JustoEny
    JustoEny New Member
    bumpp
  3. JustoEny
    JustoEny New Member
    bummp need help asap
  4. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    What OBD is the distributor? What engine harness mods did you do?
  5. Ethan
    Ethan Well-Known Member
    could you give us a bump and answer the question?
    me out:rimshot:
  6. JustoEny
    JustoEny New Member
    i have the stock jdm obd0 b16 dizzy and i just bought a new ls dizzy stock si harness i wired knock sensor ,vtec,vtec pressure,2nd o2 sensor everything came out perfect its just the dizzy with this crank sensor issue car starts and runs fine just hesitates a little when you press on the gas pedal softly
  7. JustoEny
    JustoEny New Member
  8. CAFROG
    NOR-CAL
    I may be wrong but I do not think you can use a LS dizzy on a B16.....
    Second O2? OBD2A ECU/motor???
  9. hondafreak513
    hondafreak513 New Member
    O hi O
    You can CAFROG its just that the bolt holes don't line up... and second yeah obd2 in a obd0 car.. why would you wire up a 2nd o2 and knock sensor..
  10. JustoEny
    JustoEny New Member
    um i wired the 2nd o2 sensor and knock sensor cause i have a obd0 pr3 GSR B17vtec ECU
  11. CAFROG
    NOR-CAL
    Didn't know that there was an OBD0 ECU that needed two O2 sensors.
    It hesitates with both distributors? (you spoke of a OBD0 B16 and OBD0 LS)
    What is the Electrical timing right now?
    Did you change the timing belt and maybe the mechanical timing is off a tooth?
    Any CEL codes?
  12. isthisnameok4u
    isthisnameok4u New Member
    GSR b17 ecu is a p61 and it's obd1
    pr3 is a JDM b16 obd0
    unless it's a pr3-j00 or the pr3-j51which came from the JDM integra xsi with a b16 and it's obd1 also. Check for the -j00 or -j51 after the pr3. If you have one of thoses ECU's then you will need an obd1 dizzy, or find the obd0 pr3 ecu. I hope this helped.
  13. lizz7750
    lizz7750 New Member
    try switching the plugs on your iat sensor and iacv
  14. ls94civic
    ls94civic New Member
    vermont
    the timing could be off a tooth . pull it apart and check all the marks
  15. invisibledemon
    Tn
    get a multi-meter.
    find the correct wire for the crank sensor.
    test it.
    either you need a new dizzy, or theres something not hooked up/grounded correctly.
