91 CRX w/Integra Suspension
Discussion in 'Wheels / Suspension / Tires / Brakes' started by parkerfly, Oct 5, 2006.
  1. parkerfly
    parkerfly Junior Member
    Have a 91 CRX with 91 Integra suspension components front/rear. I'm planning for suspension upgrages for next year, would like to...
    • use coil overs to balance/lower the car
    • stiffen the suspension up
    • have adjustable suspension to fine tune the handling
    Will I be able to lower the car much using Integra suspension which uses longer compenents... or will a lowered Integra susp be about the same as the average CRX suspension?
    Suggestions for springs/struts? Tien? I am running a stock front sway bar with no rear sway bar right now. I like the way this handles now but will probably have to play with that setup when I change the suspension.
