91 da starting problem
Discussion in 'Integra' started by 91da, Aug 10, 2008.
  1. 91da
    91da New Member
    hi i got a 91 da ls with a jdm b16a. converted the obd1 b16 to obd0 and repinned the dizzy to obd0 to drop in the da then ran a obd0-obd1 ecu jumper harness. the car does not want to start the codes the ecu is putting out is (4-crank angle sensor or cercuit,ecu...20-electrical load detector or cercuit). so heres the problem im pretty sure now that im running the obd1ecu the car is pretty much obd1:confused: does obd1 have a crank angle sensor,and what is the electrical load detector or curcuit, and how do u fix it any input would be apprecieted thanks.
  2. 89' Project Civic
    89' Project Civic d16a6/d16y8 "mini-me"
    St. Catharines, Ontario, Canada
    The ELD (Electric Load Detector) is pin B19 Green/Purple. I just took the one off my 89' Civic DX and threw it in my 90' Civic CX works fine. If you can get the ELD (which is in the fusebox on the passenger side shock tower), you'll see the Green/Purple wire in there!. Also when installing you must hook the black/yellow wire to the relay near your pass. side headlight and the other black/yellow must be hooked into the Z bend harness near the circle harness in your engine bay!!. You'll see, if not pm me or ask questions via this board. Thanks.
  3. b16vt3c
    b16vt3c 95 EJ1 d16z6 turbo'd
    woodbridge
    CHECK THE MAiiN FUSE CUS ii HAD THE SAME
    PROBLEM ON MA 94 EG HATCHBACK W/JDM B16A
    &+_ ii CHECK DAT &+_ iiT STARTED GOOD &+_
    RAN STRONG &+_ FAST
    CHECK DAT B4 U CHECK ANYTHING ELSE OR
    CHANGE DA ECU
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    do you always type like that
  5. salvadorrivas13
    salvadorrivas13 New Member
    San Jose CA
    i dont think OBD1 has a crank angle censor. I put a 94 gsr in my DA and it gave me code 20 its been a year know and still no problem. i cant fix it cuz i dont know wat to dooo. hehehe. I think only OBD2 engines got crank angle censors. check your knock censor maybe its unpluged...............
  6. 89' Project Civic
    my obd0 D16A6 91' Civic Hatch has a crank angle sensor. we'll I just did an mpfi swap and the blue/green and I think blue/yellow wire going to C1 and C2 are CAS's!
