BaDarkus91lsvtec
K so I put in a stage 3 crapy xtd clutch and flywheel in my stock d15 and about 6 months later it started slipping to the point to where I would be on the freeway and barely give it gas and it would just slip away. Could barely keep at 70. Turns out I was able to adjust it at the cable adjustment and that lasted about 1 month and now it even worse. Torqed the flywheel bolts to spec and there is no oil on the flywheel. Any diagnosis
