91 dx hatch b16a swap ?'s
Discussion in 'HYBRID -> ED-EF / DA' started by etccatz, Sep 24, 2003.
  1. etccatz
    etccatz Junior Member
    ok first question, what did everyone do with their power steering pump since the dx doesnt have power steering??? also how did you get the mounts to line up that is the big problem i cant get the mounts to line up do i have to just keep trying and eventually i will get it because i have been trying for 3 days now and i just cant seem to persuade it into position?? thanks for the help ahead of time
    ~Bill~
  2. zcrex
    zcrex Senior Member
    did you buy new motor mounts? if not your gonna have a good time tring to get it to fit. and toss the power steering
  3. 2phatt
    2phatt Member
    Georgia
    ectcatz, Sounds like you need to do some research.
    Try this link It shows the most common items needed for your swap.
    http://www.hasport.com/Products/Mount%20Ki...ount%20EFB1.htm
    I want to tell ya to just keep trying, but I pictured you trying to use your
    stock mounts with that motor for 3 days.
    Ralph
  4. Uppertorso
    Uppertorso Senior Member
    Winnipeg, Manitoba
    just remove your power steering pump/hoses/brackets, and put them in a box. Then take the box and throw it in the garbage, because you can't give that shit away. I tried to sell mine on ebay, and no one would take.
    :nutkick:
  5. etccatz
    i have the mounts thats not the problem its just super tight in the engine bay and hard to manuver around!!! but is there any trick that would help with getting the mounts to line up without kicking the shit out of engine?????
    ~Bill~
  6. brian11to1
    brian11to1 Senior Member
    are they after market mounts cause D series mounts wont work on B series motors... have wired for MPFI, VTEC? Anything? Do you even know what they hell you are talkin about.... The mounts you have, what are they from? The D Series? Tehy wont work...
    Probably NOT so... :newbie: Do some motherfuckin research before you post stupid fuckin questions.... I think all n00bs should learn to research, cna someone write a how-to article on RESEARCHING BEFORE POSTING?
  7. etccatz
    ok ass i have b series hasport mounts for a b series engines ok does that help you out dick i came on asking a simple question and who the fuck are you to tell me i need to do research i have done alot of swaps in my day just nothing compact thats why i have decided to try something different so why dont you go and fuck yourself because if you are not gonna answer the question you shouldnt reply dick!!!!!
    ~bill~
  8. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    hey 91 dx's did come with power steering. But as for what you need to do is frist the dpfi to mpfi swap the vtec. if you do a search on the subject i posted about 2 pages in a detailed how to
  9. etccatz
    ok i got all the wiring done the only thing i need to know is should the engine just fit right into place or does it take some working to get it in????
    ~bill~
