91 ef's
Discussion in 'HYBRID -> ED-EF / DA' started by hatchnate91, Mar 29, 2007.
  1. hatchnate91
    hatchnate91 New Member
    i need speed i'm somewhat of a medium tech, workin on master's level but i ineed answers to what i should do i have a 91 ef. ineed to know what series B or D or zc would be my best option but i want reliable speed,plus something to build on?^_^
  2. sleepercivic69
    sleepercivic69 New Member
    i got a d16z6 in my 91 hatch and im very happy. theyre pretty cheap and with some work you can get as much power as the b series
  3. dzx69
    dzx69 b16aEFGino
    Philippines
    Well I would also try and suggest you go for b16A's... I fot an EF with one on it. Had no serious problem with mounting it just fit right in :)
  4. hatchnate91
    so what about the crossmember no mods to it because back at school (lincoln technical institute) a buddy of mine in fuels class had a 91 crx and he had to make mods to jis b16 swap when it came down to the crossmember.
  5. efhondakid
    Akron-Canton, Ohio
    I'm puttin a b18a1 in mine, cheap and makes good power. It depends on what mounts you are using wether or not you have to pound the lip down so the mount sits flat, not really a mod just some hammer work
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    If you're looking for cheap, stick with the D-series. I spent about $450 on my complete engine swap and some mods and I'm able to beat some B-series(especially a lot of the non-VTEC ones). Having a light car really helps. With a built N/A D-series you'll be looking at around 130-160whp with off the shelf stuff. Going higher would mean custom work, thus a B-series would be better. You probably don't even have to swap; but just work off of your stock engine. Plenty of guys making decent power on the non-VTEC heads and if not that you can always do a mini-me.
    If you're going to build it and make some power; you'd want to move up to the B-series or maybe even the H/F(not as much parts) or K's.
  7. candyblueEG
    candyblueEG Junior Member
    my ef has a b16a with a t3/t4 and i smile every time im in it and its not even tuned yet about 4.5 lbs of boost and it already screams. the sound of a honda motor hitting vtec, with turbo spool and a blowoff is a sweet symphony
  8. nulowz_uncivil
    nulowz_uncivil New Member
    Fort Meade, MD
    i'm running a JDM B18B with a fully built Y1 cable trans w/KAAZ dif, innovative mounts, underdrive crank pully, fuel rail, FPR, MSD cap/rotor/external coil/wires, custom ITBs, JDM type-r spec header, test pipe, and a greddy exhaust, mine screams just fine for me.
  9. 91efvtec
    91efvtec New Member
    PA
    im runnin a d16z6 in a 91 ef hb....i chose it because of my budget...if i had the cash i would have def went with a b series...i put in the engine and also changed the tranny from a 4 to a 5 speed also had to convert to obd1...the only trouble i had was the wiring harness on the engine...just sent it to rywire and they took care of all that bs..they sent it back ready to just plug right in...i am very happy with the swap, and it was also the first time i did something like that, this site was a huge help these guys are good and this shit!....the engine is a jdm engine i got from j-spec auto.com. i spent bout a grand on everything...hope i helped good luck bro
  10. 91efvtec
    91efvtec New Member
    PA
    but def def go with a vtec you wont regret it
