91 engine question
Discussion in 'Civic and CRX - EF' started by bengalari, Apr 3, 2009.
  1. bengalari
    bengalari New Member
    i understand the size difference, but a friend of mine is looking to get rid of their 91 crx 5spd, the engine is dead. I have a 91 accord with body damage not worth fixing, but engine and tranny were recently rebuilt, is it possible for me to swap the 2.2l accord engine into the crx? has it been done? how much work would it take?:confused:
    hope to hear something soon, thank you for your help.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yeah it can go in there but you will have to buy some mods and mounts
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    it uses the H series swap mounts,im pretty sure the fseries motors used shift cables instead of a linkage,so you will probably need the cable setup,look up Hseries swaps into an ef
  4. bengalari
    thank you, i'll post again if i run into new problems
