91 engine swap
I have a 91 accord 2dr coupe with a plain jane 16 valve engine in it which is shot, I found a 94 accord 4dr with a vtec and I was just wondering if the vtec would go in the 91 accord any help would be very much appreciated
uhhh...nope.
You have b-series motor & want to install f-series.
So, I'm not going to say that it wouldn't fit, because I don't know. But it will not be a drop-in swap.
Good luck.
uhhh...nope.
Good luck.
Dude...what are you talking about? Accords don't have B-series motors...
He's got a 91 Accord, so it already has an F22. He wants to know if he can swap in a VTEC F22 from a 94 Accord. The answer is yes, and it should just drop in and bolt up. Both the car and the motor are OBD1, so you won't have to do any conversions. You'll also need the 94 EX ecu and to run the wiring for VTEC, but other than that, it's cake.
