Got my 91 Teggy up for sale.
This car has a spun rod and I started to take the head off and you can see the pistons now. The block loks fine. I have not dropped the pan to confirm spun rod, but it started knocking pretty good and I am sure it the bearings. First to $500 takes it or shoot me an offer.
I have no time to work on this car as I am a full-time student. Great car to drop a new engine or rebuild current one.
~215K on the body
B16A+Tranny with roughly 90K
Chipped ECU, VTEC set at ~4500 RPM, speed+revlimiter removed
White with fairly good paintjob
New Outer Tie Rods
16" Konig Monsoon rims
New Distributor, cap, wires and spark plugs
Lowered with camber kit front and rear.
JDM one-piece headlights
New Fuel Filter
Intake
Exhaust with high-flow cat.
New Axles
I am probably forgetting a few other things...
Rent a $40 U-haul trailer and pick it up!
The body has some minor rust around the rear fenders, and a hole about the size of a fist on the right rear fender. There is a dent on the back just below the left tail light.
~215K on the body
New Outer Tie Rods
New Fuel Filter
Intake
New Axles
