91 Integra LCA and Swaybar in 94 dx coupe
technolud
I want to upgrade the suspension in my 94 dx coupe. I got a 19 mm rear sway bar and want to go with a 21 or 22mm front bar. I have access to buy a 91 Integra front bar and LCA's. Will these fit on the 94 dx? Other then this going with Eibach Pro-kit springs, KYB agx's, sway bar mount stiffiners and adjustable camber front and back. Setting up the car for street plus auto-X. Thanks
I don't think they'll work. IIRC, the LCA's up front are like the EF's. If that's the case, they're different because the EF/DA uses a radius arm bar to keep the LCA's from moving, while the EGs use a "A" shaped LCA with no radius arm.
