cycloneb18c3
Ok I have a 91 integra with a b16 swap. Im wiring my car for vtec into a pr3 ecu. and Im a lil confused...
here it goes
PIN B19 on the stock PR4 is a p/s pressure switch, the PR3 Requires this to be the knock sensor. Do I just take the p/s pressure switch wire and replace it with the knock sensor wire? and re pin the p/s pressure switch to pin C9 on the PR3?
For the 02 sensor wiring-Ive heard to run the ecu you need 2 o2 sensors. I got a pinout for a PR3 and it only shows 1 o2 sensor. Most people say to wire vtec you have to run the 2 o2 sensors. for the first one I run the wire to pin C8. My car stock only has 1 o2 sensor. IF there is a second o2 sensor needed which pin does it go to, and could I split my o2 sensor wire into 2 and run one to c8 and one to what ever pin it might be? Sorry if its confusing, I cant really explain it any better.
for the vtec pressure switch there is 2 pins for the plug on the head. 1 of them goes to the ecu. where does the other go? Other that Im good to go.
thanks in advance for your help
Dan
here it goes
Dan
