91 integraswap obd2>obdo
b16acura
im plan on swappin a 99 si b16a2 into my 91 integra i kno i need a cable tranny fot this swap to work , and i know i need to convert from obd2 to obd1 , but is that all i need to change?some people tell me I need new distrubtor,injectors etc. can anyone tell me exactly what i need to complete my swap????and will any obd1 ecu work????
buy an OBD0-OBD1 conversion harness get an OBD1 ecu,dizzy, injectors and the cable tranny
[post=480370]Quoted post[/post]​
so will i need two coversion harness's one that will convert my motor from obd2 to obd1, and another that will convert my car from obd0 to obd1?im ready to buy all the parts i need jus dont wanna spend money on parts i dont really need.has anyone ever done a similar swap??anymore feedback would be great.
your goin to need one conversion harness.....a obd0 to obd1.....then get a p30 computer which is a b16 obd1 computer......u need a obd1 distributor....obd1 injectors and get the plugs for both of them cause your goin to have to swap over your stock injector and dizzy plugs to obd1 plugs
Ahhh...too much misinformation
YOU DO NOT NEED TO CHANGE OUT YOUR INJECTORS!!!!!!!!!!! YOU CAN RUN THE OBD2 INJECTORS ON A PRE-OBD(OBD0) ECU!!!!!!
You can run the OBD2 distributor with an OBD1 ecu.
You can do the following:
Run an OBD0 distributor, 1 wire O2 sensors and the OBD0 ecu
Or
You can run everything that you have and purchase an OBD0 to OBD2b conversion harness.
http://www.jkobd.com/0to2b.htm
Or you can run the OBD2 distributor and only need to find an OBD1 ecu and go with the OBD0-1 conversion harness.
http://www.jkobd.com/0to1.htm
Chipped OBD1 ecu:
http://www.jkobd.com/tuning.htm
Either way man. You have many options.
