91 Ls/vtec Turbo
Discussion in 'Forced Induction' started by 91gsrturbo, Mar 21, 2003.
  1. 91gsrturbo
    91gsrturbo Junior Member
    i have a 91 integra with a ls/vtec and i just put a t3/t4 turbo kit on it and the tial waste gate is not opening it will keep pushing psi any info on what to do and it will cut out very bad at 8-9 psi do you know way and how to fix it Thanks :huh:
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    what is the waste gat set at
  3. 91gsrturbo
    i dont know the size of the spring. what do i need to do to find out. and what size fuel injector do i need to run from 5 to 10 psi Thanks
  4. pissedoffsol
    550s should cover you.
    and springs in tials go from 4 psi to 25 psi. so who knows what you got.
