91 Manual Dizzy vs 91 Auto Dizzy
Discussion in 'HYBRID -> ED-EF / DA' started by Reboticon, Oct 19, 2008.
  1. Reboticon
    Reboticon New Member
    Knoxville
    Is there a difference between these two distributors except perhaps for connections? Autozone lists a different part number for auto/manual and im trying to figure out what i need to change to make one work for the other. Is it most likely just connectors?
  2. monotech
    monotech Member
    The connectors are the same for both the one you need is stamped on the casing TD-18U but TD-02U is also compatible so to answer your question yes you can use either one.
  3. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    No
  4. Reboticon
    Knoxville
