D16SiHatch
Active Member
i figured a high reving B18 wouldn't hold a candle to a high reving B20. but i again... i know shit. let me know
the b20's are designed for more low end tq, so they don't perform as well in the high end. regardless if you build them to handle the extra few hundred rpm. the engine was designed for and originally put into a crv. so it shouldn't be a mystery as to why a high revving vtec b18 would in most cases be faster than a b20. Also the rpm you're sitting at on the freeway has everything to do with what trans you choose, and nothin to do with the engine itself. 4k at 70 sounds like a b16 or gsr tranny. i don't personally like the rpm's that high, even if it does make you faster, so i plan on sticking with an ls tranny. maybe drop a lsd unit one of these days.
