91 SI dizzy on Z6 head
reckedracing
TTIWWOP
VIP
i heard the SI dist will bolt to a z6 head, but only with 2 bolts
can anyone confirm?
does anyone know if there are wiring changes between a dpfi and mpfi from the engine harness plug to the ecu?
i assume all wiring changes are in the actual engine harness, and not in the harness that goes from the bay to the ecu...
whats the diffrence between 91 si injectors, and 92 z6 injectors?
ok
i think the SI dizzy will work...
I think there are wires missed from the dpfi ecu to bay harness, so i would need to add wires, or just get a full SI harness...
the injectors are peak and hold vs saturated...
excellent
anyone have any opinions?
