91 si z6 swap
Discussion in 'HYBRID -> ED-EF / DA' started by autox 89 dx, May 22, 2010.
  1. autox 89 dx
    autox 89 dx Member
    SF bay area
    Well I finally blew up the mini me swap and got a d16z6 out of a 95ex. I put it in yesterday and the only prob I ran into is the double pronged temp switch on the back of the block next to the oil filter is not on the z6. I see that on the water neck by the lower radiator hose on the block (z6) has a switch can I just splice the harness wires to that switch?
  2. egb19c
    egb19c New Member
    Yep. Just cut the connector off your ef harness and extend the wires and add the new plug that fits the d16z6 radiator fan switch that is on the thermostat housing. Simple as cake. Good luck!
  3. 34diesel34
    34diesel34 Import Tuner
    USA
    Just splice it. As long as the connections are made it will work:thumbsup:
  4. autox 89 dx
    autox 89 dx Member
    SF bay area
    thanks it got it workin today :thumbsup:
