91 swap
91CivicSIR
i have a 91 civic si and i doing my b18a swap. I heard that i could use front left mount out of 90-93 integra true or false
can i use shift linkage to of the same?
you can use the 90-91 mounts but you'll have to weld in the mount on the passenger side by using two steel plates. You can also use your shift linkage but you'll have to extend it a little by using a pipe to extend it.
