92-93 headers to 90-91 DA
Discussion in 'HYBRID -> ED-EF / DA' started by Sn0rKy, Aug 13, 2006.
  1. Sn0rKy
    Sn0rKy Junior Member
    i have a set of 92-93 megan headers that i am trying to fit to my 90-91DA has anybody done this?
    i know i need to extend the o2 sensor, and the exhaust to fit it.. but is it worth the trouble? or should i just try to find a 90-91?
  2. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    How many headers are you planning on using on your car?
    ^_^
    They should be a direct replacement. 91-93 are the same I thought... idk for sure....
  3. pubes2942
    pubes2942 New Member
    If you can find megan headers for 90-91 then i'd do it and then tell me where you got them.lol. and ya there is a difference because the 02 sensors are in different spots. what ever is cheaper. the thing is i dont know if the censor when extended will fit right. because 92-93 (obd-1) have 3 wires and i was sure that 90-91
    (obd-0) had one wire.???
  4. F22HB
    F22HB New Member
    You should go to ebay, you can get 4-2-1 headers, downpipe, and a hi-flow cat(test pipe) for $90. Polished stainless steel, I got some, they look really nice. THANK YOU CHINA!!:D
  5. brian11to1
    brian11to1 Senior Member
    no they arent.
    the length of the catylitic converters are different.
  6. Sn0rKy
    i think its pretty much just the length of the exhaust thats different..
    but i got the header cheap, so im going to extend the exhaust piping.
