92-95 B16a2 Into 00 Hb Dx
Discussion in 'ECU's, Electronics, and Tuning' started by Holy_racer, Jan 6, 2003.
  1. Holy_racer
    Holy_racer Member
    I just got my motor and it's a b16a2 obd1, but my car and the ecu i'm going to use is an obd2. I was just wondering if any of you guys can help me out. Also, i need help with the vtec wiring on my dx harness, do i have to cut anything?
    Any help will be appreciated.
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    IF you would have done it the other way, going obd1 car with obd2 engine, it would have been alot easier. You went the wrong way. Going obd2-obd1 is tuff, alot of wiring.
  3. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
  4. B16
    B16 Super Moderator VIP
    yay area, CA
    keep in mind that it is not legal... and i thought b16a2's were obdII?
  5. asmallsol
    yea they are but for some reason, some shops lable that engine on there site as the b16a2 obd1 instead of just putting b16aSiRII
  6. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    it's gotta be a jdm b16a2, unless it has obd1 shit on it from somebody else which is just as possible..... in a nutshell save your self from a whirlwind of shit, just buy a p28!!!!
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Does it actually say B16A2 on it?If so it should be a USDM or EDM.If it is USDM it is probably OBD II cuz the OBD I delsol vtec is harder to find.
  8. B16
    yay area, CA
    not to mention that one is called the B16A3
  9. xj0hnx
    C.C.TX.
    Thought about that,but hey,they're hard enought to find.
  10. prawjEKt Cx
    upstate NY
    so jdm sir-II's don't have b16a2 stamped on the block?? well i'll be dammed
  11. asmallsol
    no all jdm engines have a b16a or a b18c, there are no numbers on JDM engines (except for diplacement #'s)
  12. MaaseyRacer
    San Francisco, Ca.
    it is not legal if you live in california, i am not sure what state you live in but that is how to work with the engine you have....
  13. xj0hnx
    C.C.TX.
    There is the one rare instance of the b16a1 JDM(forgot which car it came in)that does,but that is it.
  14. asmallsol
    it was in the JDM cr-x
  15. xj0hnx
    C.C.TX.
    :blink: DOH!!Thanks(insert into brain and retain it this tme)
  16. Holy_racer
    Holy_racer Member
    It's more like you guys are argueing than helping me out. It's all good man, i already got it all wire up. Obd1 to Obd2, it's easy once you get down to business and wire it up. Hopefully, you guys know how to do the same thing too because i only know how to wire it, but don't know how to get instruction.
    Thanks for the help dumbasses!
